If i smoked, i'd light one up and take a long satisfying drag off of it after that episode.
The workmanship on those cross braces was superb as with everything else and the
inverted rivnuts was definitely out of the box. Those nylon hardline supports touched me
in places i knew i had, but thought only i could touch them.
Chartreuse Microbus said
Apr 5, 2018
Forgive me if I'm being dense but what does the "PTO" on the cross members signify?
bmwmaniac said
Apr 5, 2018
PTO = PLEASE TURN OVER
Apr 5, 2018
I saw that and wondered what the significance was. Thanks
Apr 6, 2018
Cool, Thanks!
Apr 6, 2018
Mind you, if you are under the car - say, in a pit - it is asking your to turn the car over.....
Roffe said
Aug 30, 2018
Does anybody know what kind of flexible brake line they're using? Should be a lot easier to run under the car than copper line.
Roffe,
Not off hand, no. I found nothing in the parts list either http://www.badobsessionmotorsport.co.uk/parts-and-materials/ . But I suspect they are still running seamless tube for the main runs, and using the braided flex only at the end points to accommodate suspension/steering movement.
-- Edited by GrayRaceCat on Thursday 6th of September 2018 08:31:11 PM
Cool, Thanks!
Roffe,
It's this: https://www.competitionsupplies.com/hose-fittings/smooth-bore-ptfe-hose-fittings-for-brake-clutch/stainless-braided-smooth-bore-ptfe-lined-hose
In -3 black coated for the brake lines and -4 for the reservoir to m/c feeds and clutch hose. (Not fitted yet)
