Saw the tease on Facebook. Not sure if I can survive till Friday! I'm guilty of refreshing the youtube channel, just hoping I'll get lucky...
Jul 22, 2016
Not yet....
NOW!
Jul 23, 2016
Well done chaps.
I did spot some bother for you later on. The fuel sender unit "float stick" will stick out of the bottom of the tank when it's empty and it will hit the internal baffle when it's full. :(
I'm sure you'll figure something out. :)
JohnD said
Jul 24, 2016
Nick rejected steel as the material for the fuel tank, because he was "unsure of its long term exposure to": Toluene? Toiling? t'oiling??? Toy Ling???? (well known Chinese rally driver)
What was he on about? JOhn
Arrangemonk said
Jul 24, 2016
Toluol, its fuel
Jul 24, 2016
I thought he was talking about Toulene which is sometimes added to fuel to boost octane rating.
Fab! (if you'll pardon the pun!)
You want luggage room and a spare wheel?
it's all been done before :D
-- Edited by Forsh on Sunday 24th of July 2016 10:43:01 PM
Jul 25, 2016
The spare wheel may fit in the boot, but it's solid, so may transfer any crush towards the tank.
I doubt anyone's going to want to sit on the rear seat, so just accept that it's for luggage
JohnD said
Jul 26, 2016
That supplies the right word, but not why there is problem with toluene and mild steel.
It's not corrosion, so what is it?
JOhn
Jul 30, 2016
John, the mechanical engineer in me kicked in and I had a look at the material safety sheet for toluene (methyl benzene) and I can't work that out either, the recommended material for storage or cladding the storage container is mild steel or cr steel and most definitely not aluminium.
Come on guys, what is the problem you are trying to avoid?
Aug 2, 2016
OH JUST DUCKY . TOY ON THE SHELF THAT LEAKS OIL, AND HAS PARTS FALLING OFF THAT "ARE OF THE FINEST BRITISH CRAFTSMANSHIP' AND NO DOUBT "LUCAS" ELECTRICS FROM THE PRINCE OF DARKNESS!!!!!
Aug 4, 2016
ALSO A QUICK QUESTION" WHAT THE HELL IS LINNISHING? HERE IN THE COLONIES WE HAVE GRINDING ,POLISHING,BUFFING,METAL FINISHING,BURNISHING, ETC. WHAT IS BLACKHURST ABOUT? I UNDERSTAND THAT THE UK AND USA ARE TWO COUNTRIES SEPARATED BY A COMMON LANGUAGE (O'NIEL) BOOT,LOO,LIFT,LORRIES,TUBE,FOOTBALL.......BUT WHAT IS LINNISHING?SWEDISH??????
Aug 4, 2016
BLACKHURST WILL TRIM TO PROPER LENGTH I AM SURE (EEHHHH MAYBE)
My twocents,
"Entry from British & World English dictionary
Definition of linish in English: linish
Pronunciation: /ˈlɪnɪʃ/
Origin 1970s (as a verb): blend of linen and finish.
verb [with object] technical Polish or remove excess material from (something) by contact with an abrasive moving belt: after mitring, the tube is cleaned, degreased, and then linished"
Aug 5, 2016
GRAY RACE CAT.....MANY THANKS! IS THAT SOME KIND OC ****NEY SLANG? LINEN AND FINISH? OR IS IT A BLACKHURST ISM?
Aug 5, 2016
It looks like you spilled milk over your keyboard, your caps lock is stuck on.
gben, No clue, I just googled it. I'm in the colonies too, California. (a transplant from the original 13!)
-- Edited by GrayRaceCat on Friday 5th of August 2016 08:32:28 PM
racer-john said
Aug 10, 2016
Not yet....
NOW!
Toluene?
Toiling?
t'oiling???
JOhn
JOhn
My twocents,
What is the date for this episode, please,
www.youtube.com/watch
HTH
MESSAGE FOR BEN. YOU CAN STOP SHOUTING, YOU ONLY HAVE TO HIT THE CAPS LOCK
Paul
