What happened to the idea of fitting an air conditioning system in the mini?
landranger said
Nov 21, 2016
they have , its call windows that open ???.
going by what I have seen on the videos they are having trouble fitting thing than need to make it go and stop never mind fancy bits like heating and cooling , sorry the heating is already in the exhaust ???
Nov 22, 2016
Air-con will be fitted later, they need to fit the Turbo and other ancillaries yet, I reckon the air on system will either be fitted or rejected depending on space after that.
Nov 24, 2016
perhaps an electricly operated a/c independant of the engine?
Mini_Madness said
Nov 24, 2016
need to fit the water pump before all of that, then you get to think about weather the AC will fit. after that most people think about turbos but this is BOM and turbos come first, so does tea to think of another way around this
Nov 24, 2016
Actually, I think a LOT of alcohol came first, this just reeks if 'I've had an idea... it's a good one...'
