Post Info TOPIC: 5S-GTE Camry
5S-GTE Camry
Hey guys, I have 1993 Toyota Camry with a franken engine made from a 5S-FE & 3S-GE head and a Garrett GTX3076 slapped on.
Here's a couple of pics:
Nice work!
What sort of power output is that giving?
-- Edited by Bad Obsession on Friday 12th of June 2015 04:39:49 PM
On the previous smaller turbo it was 240whp. I want a lot more from this one, aiming for 350whp.
Very clean job mate, nice work.
It still needs a new, stronger gearbox/clutch and a run on the dyno for a tune.
I'm guessing you're still using the original S51 transaxle. Upgrading to the E-series gearbox used in the V-6 Camry should hold all the power you can throw at it. Keep in mind this will be a heavier gearbox, but not being destroyed by your high power engine makes it worth the added weight.
Already have a couple of E153s and and LSD. It is an S53 currently. In the process of obtaining new synchros and bearings.
