Post Info TOPIC: Next project.
Next project.
Found this video on Youtube and it is pretty obvious what will come after Binky. It's the Binkyboot.
https://www.youtube.com/watch?v=2x9dZLYVVzQ
Wow!
I mean WOW!
Even has a voiceover by Mr Chalmandley Warner. Not sure about those panel gaps though; there was quite a big one when they moved the mini out of the way.
That's not a panel gap. It is an air friction panel attachment method. A la episode 1. I had already suggested a certain type of camper to no one even batting an eye.
That's an impressively big panel gap when the Mini is driven away.
I bet Nik could find a way to conceal an extra engine .  It would do wonders for the power / drag ratios
And that boat would make a handy place to mount the speakers for som"Bangin' tunes"
That is quite the ridiculous addition. I would fear of cross winds in a vehicle that tall with the track width of a mini.
I think an old yank muscle car but with modern indy suspension, steering and brakes.
Maybe a late 70's camaro or a transam. Lots of room to work with!
