Post Info TOPIC: Episode 16.
Episode 16.
Work on next episode has started.
So what do you think the guys will bring us this time?
One word - ENGINE
-- Edited by The Chief Smeg on Sunday 7th of May 2017 03:00:04 PM
It's not going to be engine.
The Chief Smeg wrote:
One word - ENGINE
Metric in the streets, SAE in the sheets.
Chaps, it might not be the Engine...
I doubt it will be the arches, so wonder if it would be brakes?
Battery and/or heater.
Most of the things on my imaginary to-do list come with the engine (mounting a turbo, air filter, starter, alternator, fan, maybe TVIS, maybe power steering, oil sump, etc) or near the end of the build (glass and wipers, carpeting, paint).
There's a bunch of cabin stuff to do (gauges, interior lights, sound system, sundry controls like the turn signal and wiper stalks, etc.), but it seems like they'd do that after the engine, so the welder doesn't accidentally ruin the electronics.
I can't think of much more fabrication work: just the back seats and seat belts, final wheels, final wheel arches, and wing mirrors. Maybe heating/ventilation ducts. The other fabrication (exhaust maniford and oil sump) will probably wait for a turbo.
So my guess is... something that I didn't hadn't even thought of.
I expect the wiring will take them a while to sort out. Due to needing access holes, and to fix it to the body, this will have to be done before painting
I should think it will involve large quantities of Tetley's and many , many biscuits. and perhaps an appearance of the Llama and Nic in a sombrero to honour Cinco de Mayo!
Sod that, we want to see Mr Flibble again
Towbar!
so the battery and air-con can go in the trailer
Sound deadening and realising you need clearance for the exhaust, around the sump.
battery goes in the foot well.
Wiring that's not nearly as bad as a bowl of spaghetti.
Windows? Glass or Lexan?
Speakers??? Radio? for the emergency services to warn of this beast.
Heater what do you mean? just stick a hose from the engine bay, its bloody hot enough! + engine smells. :)
Do a Q and A episode!
Chips and a proper curry takeaway....or a nice Yorkshire puddingconfuse
 Do you think a dry-sump could be a possibility? Or is there not enough room for the pumps beside the block? I've found a couple companies in the UK that have dry-sump "kits" for this engine.
-- Edited by GrayRaceCat on Monday 15th of May 2017 08:01:18 PM
We must be due another Q&A or 'Smeg Ups' mini episode...
I can't begin to tell you how busy we are with 'normal' work and commitments. Ep 16 is coming, no idea when yet though. There's some serious conundrums to work through, some more pipe bending, the use of a lovely Mercedes OEM part to solve one problem and some other stuff too.
I can't begin to tell you how busy we are with 'normal' work and commitments...
 That'll learn ya to put awesomeness on the interweb !!!
wink
 "lovely Mercedes OEM part" So you are making a Mini Mercedes, or a Smart car. Hehehehe
The list of OEM manufacturers parts already on the car goes something like this:
Porsche
BMW
Toyota
MG
VW
Mercedes
Rover
With more to come!
We're equal opportunity purloiners.
Mitsubishi - L200 internal door handles
Vauxhall - Corsa radiator
Ford - flip front motor
Jaguar - bonnet latches
Honda - seats
Peugeot - wheels
Lexus - Magic prop shaft
-- Edited by Forsh on Friday 19th of May 2017 05:55:59 PM
Porsche
BMW
Toyota
MG
VW
Mercedes
Rover
With more to come!
 "We're equal opportunity purloiners." :)
G-Wagen drivetrain into Smart would be a worthy challenge. Although you'd have to be pretty mad to want to do that.
-- Edited by andsetinn on Saturday 20th of May 2017 09:50:28 AM
hows about we compile a complete list
This project is an Austin Mini with Celica 4wd mechanicals somehow rammed into it - so it seems absurd to list any maker / source of components above these manufacturers
watched "CARS THAT ROCK" w Brian Johnson frm AC/DC  he had a father /son team from Italy that put a V-12 from a Murcialago (Lamborgini) into a Fiat Cincuacento (500) into the back seat.....confuse  it was very beautiful  they did a great wide-body in all metal . and it was "FAST"!!!!!!!
Mercedes bonnet catches?
Needs more testing on "private property"
Ok. So here is what I am thinking. If BOM would make monthly 10 minute episodes, and then quarterly 3 episodes combined into one "director's cut". It would show us more of the dead ends that the design goes into and probably be more interesting. It takes about a day to record 10 minute episode, 2 days if there are lot of tea breaks so everyone should be happy. Right?
-- Edited by andsetinn on Wednesday 12th of July 2017 09:47:12 PM
hi andsetinn , all that would be good if binky was the only thing they are doing but I think we are forgetting that the guys are also trying to run a business so they can pay for the binky project .
whatever they are doing will be done right and well thought out .
next project I thing so they have more room to put stuff austin maxi with Subaru / mitsubushi running gear .
keep up the good work guys (how about posting some teaser pics of how its progressing )
andsetinn wrote:
and probably be more interesting... Right?
 Wrong IMO!
There's not much that's interesting enough for me to watch, rewatch and rewatch again but BOM & Binky fit the bill...
(...and the original*  Italian Job and Life of Brian)
(*superfluous word)
Landranger. Surely, even if they are busy, they work on Binky couple of days a month?
Forch. How can more Binky not be more interesting?
1) I wish there were a way to eavesdrop on the brainstorming sessions the lads must have when problems arise.
2) Maybe a webcam or two on Binky so we can watch live, would be a good security measure too.
I'd love to see more Binky, more often but you made it sound like there was a lack of 'interesting' without additional content
The anticipation of the next episode just adds to the appeal as was talked about in the Crossthreaded podcast
E J Potter (famous m/c racer) put chevy V-8 in H_D frames and went like crazy in the 1960's said very eloquently..."Ignorance is a powerful tool if applied at the right times, usually even surpassing knowledge." He made exhibition runs in England.......When was Nic born ?...looks a bit like him!
come on you guys at BOM we are getting impartation for a small snippet of what's happening with binky , please give us a update on what's been going on in the garage ???
how about some pics or video snippets
How's it going guys?
Any Ep. 16 teasers?
"EP16 ETA?"
Shortest Post in history
-- Edited by MiniMan on Sunday 6th of August 2017 02:09:23 PM
The Mini that BMW should have made
Here's the thing, we've had a nightmare with the car this last couple of months. Working through some fiddly issues that have pissed away day after day and not got us anywhere. We're trying our best to get it out as soon as possible but day job is also getting in the way. The edit of what we've got so far has been started, so we're definitely getting closer. Sorry.
Dear BOM,
Please don't feel you have to be perfect.
"Misery loves company",
"We're in it for the long haul.",
"The only Good Cliché is a Dead Cliché"...
p.s.  Besides, you learn from your mistakes, let us learn along with you. It's one of the reasons I'm here.
An agreement with GRC.
The workshop can be a sanctuary from the monotonous employment necessities. Maybe it might be time to invest in a time lapse camera pointed at a couple of corners in the workshop. I am willing to watch you pick your nose and eat it. (In time lapse, no one can hear you scream.) As well as see the mistakes and reality of doing something no one else has ever done. I also understand that investing more time in anything that includes the labor intensive JOB of editing any video is probably not in the cards either. It just would be nice to see something even if it is 10 steps back...
A quote from my favorite show to the North of me. "Keep your stick on the ice. Remember, I'm pulling for you. We're all in this together." [The Red Green Show]
Like everyone else, I'm desperately keen to see the next episode. I do wonder, though, if a lot of time is dedicated to the slickness of the show rather than the work on the car, and I don't just mean the significant amount of time and effort taken for editing. The out-takes video makes it look like you spend a lot of time refilming a lot to get it just right. I get that with the jokes - timing is everything - but I'd be happy to see less polished performances. I don't care about someone hesitating, getting tongue tied or not using the very best description of what they're doing; I think an "au naturelle" approach would work just as well for you two - the engineering and craftmanship would not suffer (it'd probably benefit), and you guys have enough humour and character to come over well without nailing the script perfectly. That's not to say I don't appreciate the effort you put in, just that I think you worry needlessly about making the videos too polished.
 Not really. The pieces to camera aren't scripted at all, it's just a question of nailing what we're trying to explain without making less sense than normal. The filming takes a lot of time, but the "slickness" doesn't really effect it. The time just disappears when you're stuck in a corner trying to think of a way to fix something, then making it. Then life and jobs get in the way too. Plus, you may have noticed, but we don't really like just nailing something together. Whether it's the car or the video production, we strive to do the best we can and improve all the time. The extra effort involved had no real effect on the time taken to be honest, it might save us a couple of days, but it's not worth the sacrifice to us.
-- Edited by Bad Obsession on Monday 21st of August 2017 01:31:24 PM
It's a great job you guys are putting up here and I'm really looking forward to see it when it's completed! I'm impressed that you managed to produce this many episodes in such a short time considering the engineering you put into this project (can't wait till you must wrestle with the electrics)! Hope you keep the fire up and let the new episodes come out soon, but please, don't rush it just because everyone being inpatient (including me). The best result isn't produced in a rush :)
Gents, nice work, love what your doing.
I'm keen to see whats next, but understand the time it takes.
I hope the frustration of redoing things does not crowd your thoughts, what you have achieved is exceptional.
Sláinte
Ha, reading the last posts I was just reminded of this:
good-cheap-fast-sign.jpg?w=676
Since the guys are mostly working by themselves on the project, we just have to stick to rule one. Otherwise they would have to hire a bunch of mechanics and that is just not in the project budget. The whole thing is a good chance to lean back and learn how to be patient. smile
BR Seb
In my opinion this is not really about the finished product anymore. This is about the journey to get there and I want to see more of the journey.
 Got to agree with you there, for me this has always been about the journey, the prize at the end is just a bonus. Boy what a journey!
 I do think there is a possibility that it could happen. however i feel it might be just be precaution to fit the sump. very closely. some heat protection might be required.
Also if that is the case removing the sump in the car to quickly check bearings is going to be an utter pain.
Anyone spotted the footprints of Episode 16 yet?
1 2  >  Last»  | Page of 2  sorted by
