Post Info TOPIC: Ep 22
Ep 22
I expect it somewhere around the end of February, to cover instrument panel, sound system, wiring up doors, wipers and all the other stuff.  Engine?  not for a long time
I have a sneaking suspicion the engine build started a long time ago and is in process, once everything is done to the engine, then all will be revealed. as with everything on this build, more than 1 part was being worked on at a time.
You know, I reckon you are spot on there!
Yep! Plus little things like the ground lug used in ep-21 that was welded on in ep-8 make me think there has been a lot more long term planning than the lads have led us (me) to believe!
They have built a few cars before, so have a pretty good idea what is needed and when.
I agree with the idea that some strands get held back and not published. The recent sudden release of three videos suggests that. I expect that they have been doing work on the engine, but are keeping shtum on it.
Don't forget after the BOM mug welding video last year there's bound to be another 1/4/19 special - bigger and better and only 10 weeks away so may delay ep 22 !?!
wink
20:00
Yey!
Bangin' t'yoonz!
