Post Info TOPIC: Wheel arches
Wheel arches
So, when are we going to see the wheel arches/mudguards manufactured from the yellow formers that are currently on the car do you think?
while we are at it, when do you all think we will see some proper wheels because it is currently clear on the “proof of concept“ ones...
My 'to do' list includes
wheel arches
charge cooler and its coolant feed pipes
inlet blow-off valve
mount turbo
turbo oil feed and drain lines
connect exhaust pipe to turbo and mount waste-gate
Strip, paint, trim, build!
Paul
I asked on Twitter about the arches...
...Nick isn't happy
The original pattern part arches didn't hold their shape so well
so will be remade!  no
Obvs!
-- Edited by Forsh on Wednesday 16th of October 2019 10:08:41 AM
Cheers!
Wonder what is happening with the wheels
Did the original Rover Sports Pack arches include a sill strip linking the fronts to the rears? It does look like there are stubs for this on ends of Binky's arches so I wondered if this will be part of the final build.
